Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Symptoms
Not Running
1989 Ford F250
1989 FORD F-250
10,000 MILES • V8 • 4WD • AUTOMATIC
MAUREENSGARDENS@OPTONLINE
MEMBER
1 POST
FOLLOW
while i was driving truck died and will not restart
Mar 30, 2008 at 12:57 PM
BLACKOP555
CERTIFIED EXPERT
are you getting bright blue spark
at
all
cylinders?
check each one, with a spark tester and make sure your using a good ground on it, if no spark check directly from coil.
you have gas in the tank im hoping? and you didn't run it out of fuel then re add fuel and it didn't start?
Mar 30, 2008 at 6:51 PM
