1988 Ford F250 no reverse
1988 FORD F-250
98,000 MILES • V8 • 4WD • MANUAL
DON86F250
Hi, A friend is willing to give me an 1988 f250 diesel with a dump bed for free but the trans pops out of reverse when clutch is engaged. Priior repair orders state the trans was out of vehicle twice, once for clutch and other time for shifter adjustment? I'm not sure what type of trans but I do know it is a toploader 5 speed. My question is can these trans' or shift levers be adjusted or would I be better off with a junkyard unit or rebuild??? Thanks in advance for your expertise?
May 7, 2008 at 2:55 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation.
I would be inclined to pull the box and O/Haul it. this way you will know that you will have a serviceable gear box and with it removed and dismantled you will be able to make sure that there is no gear tooth damage that will foreshorten the life of the box.
Mark (mhpautos)
May 7, 2008 at 4:13 AM
