1985 Ford F-250 broken injector line
1985 FORD F-250
100,000 MILES • V8 • 2WD • AUTOMATIC
TODD MINSHALL
On this enjine the fuel pump is hard to get to due to its placement. Some other less skilled person over bent an injector line that cannot be easily reached . How hard is it to remove the fuel pump to remove the damaged line?. Could you send an exploded view diagram of the pump/injector asembly.1985 ford 6.9 diesel in a van. So its cramped dark and hard to deal with.Can you please help?.
Oct 6, 2010 at 11:20 AM
TECH1FORD
  • 102 POSTS
I see someone eles sent you a diagram but to remove the pump you need a speacial s shaped wrench and then when going back together you will need another speacila tool because it has to be timed in or pump damage will happen. So sorry for your luck they are about the worst job you can do.
Oct 10, 2010 at 12:39 AM
