1979 Ford F250 V8 Two Wheel Drive Automatic
I have a 1979 Ford F250 Ranger that's really hard to start and often runs roughly. When I first start it, it starts and then dies; it often does this three or four times before it will finally keep running. I think that would be a choke problem, right? It has an automatic choke.
When I accelerate, it hesitates and sputters a little bit, but when I push the accelerator down further, it picks up speed like it should. When I floor it, the truck accelerates fast, with no apparent problem at all. Sometimes, it runs more smoothly than other times, but rarely as well as it should. I've tried adjusting the fuel mixture screws, but that didn't correct the problem. I've also put on new spark plugs, a new fuel filter, and a new air filter.
I had the truck repaired just over three weeks ago; at the time the carburetor was flooding so badly that gas was running out the top and sides. Gas still leaks out the driver's side of the carburetor a little bit, though it doesn't drip. Before the flooding started, the truck ran really well, as well as it's run since I've had it.
I would appreciate help with this problem. Thanks.
Oct 30, 2019 at 6:56 PM
(Merged)
