1984 Ford F250
1984 FORD F-250
REDDAWG0323
Drive Train Axles Bearings problem
1984 Ford F250 V8 Four Wheel Drive Automatic
I am hearing a loud steady clank when the truck is in drive.I thought maybe was the U-joints but the driveshaft does not wobble.Do you know of any other issues that could be causing this noise?
Mar 23, 2009 at 10:45 AM
MECHCURT
  • 184 POSTS
Check the front axle u joints. They sit right behind the wheels and there is a gap where you can see then on the end of the axle. W/o a better desription this is where i would start. Hope this helps Curt
Apr 16, 2009 at 1:05 PM
