1976 Ford F250 Won't shift from column
1976 FORD F-250
73,000 MILES • V8 • 2WD • AUTOMATIC
KCORRIGAN
The shift linkage from the column to the transmission won't work. Can manually shift at transmission, do you have any suggestions or a diagram of the wiring, etc to check on the steering column?
Jul 20, 2009 at 3:20 PM
JDL
  • 16,098 POSTS
Just a thought, you might call around to some of the local boneyards, see if they might have a steering column that will work. Swap out the whole column. Sorry, I don't have any diagrams of the column.
Jul 20, 2009 at 3:50 PM
