Engine Mechanical problem
1970 Ford F250 V8 Two Wheel Drive Automatic unk miles
Hi.. I have a 1970 Ford F-250 with the 360. Last year upon rescuing the truck from a field, I did a complete overhaul including new fuel pump and filter. The truck has run fine until recently. It was parked, but occasionally started, over the past few months. I am unable to get fuel to the pump or carb. There is no fuel coming into the filter ( clear ). I thought that I might be low on fuel, so I have added about 6 gallons with no luck. I tried removing the fuel line at the top of the in cab tank and poured gas into it to confirm it wasn't plugged. It wasn't. Any ideas? Should I add more fuel? I replaced the fuel filter and pump again with no luck. The truck has been parked leaning to the right on a slight grade...stumped
Oct 13, 2008 at 8:50 PM
