I have a 96 f-150 4x4 with a c-6 transmission, 103,000 miles. the transmission recently started leaking a small drip. three months later (prox 1000 miles) the leak has progressed to a puddle. the leak is in the front. I assumed the front seal so I removed the transmission and replaced the front seal (that the tork converter seats). after running the truck for 10 minutes and checking for leaks I shut it off. 15 minutes later the same puddle appeared under the same spot. it doesn't leak while idling.
Oct 2, 2007 at 7:23 PM
