still soft brake pedal
FORD F-150
LLCF-150
97 F-150 4x4 4.6L with 4wabs.
Soft(spongy) brake pedal before brake componets replaced and still the same spongy pedal.
Both front calipers,rotors,brake lines,mastercylinder,
booster check valve and replaced rear shoes and hardware.Bleed brakes 10 times with in the past 2 weeks.No Change.
Aprox.3" of pedal travel,engine running,1" engine off,
Tires will lock up on dry roads,but pedal almost to the firewall...
What else can I try,or what could cause the soft(overtravel)pedal?
llcf-150 :(
Apr 29, 2006 at 4:25 PM
CRANKSHAFT
  • 7 POSTS
check your booster if good have power blead because you have air somewhere and a power bleeder will get it out
Apr 30, 2006 at 10:54 PM
