I own a 97 f-150 4x4,4.6 liter with 4wabs.
Problem is a soft brake pedal and extra effort to brake at any speed.
Replaced master cylinder.power booster check valve,
both front calipers,hose's,pads and installed sloted front rotors and replaced rear shoe's and hardware.
Problem started after last summer from a vacation trip. Bleed brakes 6 times and used 2 quarts of brake fluid.Also checked push rod at booster,okay.
Brake pedal has 2" travel with engine off,3" when engine running.
What could be the cause? brake booster or
4wabs unit?
Any help would be great!
llcf-150 :?
4wabs unit?
llcf-150 :?
Apr 25, 2006 at 9:55 AM
