1995 F150 4x4 351.
does anyone know what the min. specs should be on the rotor`s?
Apr 13, 2007 at 4:36 PM
TAURUSWHEEL
CERTIFIED EXPERT
Why, do they need to be turned down???? I think it is stamped right on the rotor somewhere, could be under the rust...Machine shop will tell you right off the bat if shaving them will exceed minimum thickness..
Apr 13, 2007 at 6:11 PM
SERVICE WRITER
CERTIFIED EXPERT
Discard is at .96 " or 24.45 mm.
My opinion is to replace them if it is a matter of doing the brake job. I found advance auto wearever rotors very reasonable in cost and dependable as any other.
Apr 13, 2007 at 6:49 PM
TAURUSWHEEL
CERTIFIED EXPERT
I'll second the wearevers, I bought some rotors, guardian I think, they were like 9 dollars apiece, worked excellent.. kind of hard to even find a place toturn rotors, most are throwaways, like brake drums.. talking standard issue parts.
