running lights 1990 ford f-150
1990 FORD F-150
LILWHITT11707
I have a 1990 Ford F-150 with about 180k on it. I just bought the truck and noticed it doesn't have any running lights. Signals work, headlights work, brake lights work, pretty much everything but plain parking lights. Fuse panel looks good, and I replaced the switch, also all bulbs are good. Any ideas?
Jason
Jun 17, 2007 at 9:14 PM
LILWHITT11707
We removed and reinstalled all the fuses like you said, and checked the connector and switch and there were no signs of heat damage. I used a test light to check the switch, and the only one that was not getting power was #10, which says it is to the Instrument Panel and Radio/Clock. Is there anyway the turn signal fuse (the big round one) is the problem?
Jason
Jun 18, 2007 at 8:38 PM
LILWHITT11707
Hey! Yeah the fuse panel is marked on the outside cover, and there is one marked park lights, and we did swtich out that fuse and made sure the socket was receiving power, but that did not help. And yes, there are unused fuse sockets.
jason
Jun 19, 2007 at 8:30 AM
