Replace manual windows with electric windows
FORD F-150
MLANCECOLVIN
I have a 2000 Ford F150 with manual windows. Is the wiring in place in the truck so that I can replace the doors with the manual windows with doors with electric windows and just plug them into the wiring harness?
May 25, 2007 at 8:44 AM
FIXITMR
  • 9,990 POSTS
call the ford dealer and ask? i wouldn't think the wiring would be there. i dont believe it's any manufacturer's standard practice.not with the cost concerns.
Dec 16, 2010 at 2:44 AM
FIXITMR
  • 9,990 POSTS
actually, i misunderstood your question? i thought you were gonna replace the guts not the whole door. but i think when you replace door you pull out existing wiring. i dont think there is a plug that allows you to remove door with wiring intact. this is america, no 1 makes things that easy?
Dec 16, 2010 at 3:55 AM
MHPAUTOS
  • 31,937 POSTS
Often all looms are intact but not used, just pull a trim and see if the harness is there, if not you will not easily be able to do a conversion.
mark (mhpautos)
Dec 16, 2010 at 7:00 AM
