rear brake abs sensor
FORD F-150
RD3977
The rear abs light is on all the time. I have checked the brakes and they are fine. Where is the ABS sensor located? It is a 1991 F150
Nov 17, 2007 at 11:34 PM
MERLIN2021
  • 17,250 POSTS
You didn't say what year the truck is...but if no sesnors at each wheel, check the top of the differential, there you should find the RABS valve. Clean the dirt from around it before you remove it!
Nov 18, 2007 at 8:10 AM
