"86" ford repair cost
1986 FORD F-150
JPATTON
What should the labor cost of replacing just the exhaust manifold, and some minor exhaust repairs run me on a 1986 ford f-150 straight 6 if I supply the gaskets and parts for doing so??
Dec 13, 2006 at 8:28 PM
CATCH_15
  • 250 POSTS
If you have the gaskets, I would recommend replacing the exhaust manifold yourself. It's not that hard at all. As far as the exhaust repairs, how extensive is the damage/wear to the exhaust?
Dec 13, 2006 at 9:22 PM
JPATTON
[quote="catch_15"]If you have the gaskets, I would recommend replacing the exhaust manifold yourself. It's not that hard at all. As far as the exhaust repairs, how extensive is the damage/wear to the exhaust?
have to cut the exhaust off 6-7'' from the manifold connection ,add a doughnut gasket in (cause the other manifold doesn't have the flange built in) and add a sleeve over the pipe and weld/or clamp back together then replace the air valve and tube that hooks to the catal. converter.. and that's it as far as I can see..?[/b]
Dec 14, 2006 at 9:19 PM
