My ford 1-50 has a white-jelly substane under the oil cap.
1950 FORD F-150
REDNECK73
One day I added some oil in my 1992 F-150 to find a white-ish jell under my oil cap. I figured it might be a blown head gasket or crack in the manifold. It might be water or anti-freeze. The truck has 182,000 miles and its automatic. The truck burns a little oil, but when I am going about 25 mphs the oil presser drops down when i left off the gas and it likes to bog down or ride pretty rough when this happens. NOT really sure about it. :lol: hoping you could give me a fews answers on the situation because its pissing me off not knowing whats going on.
Nov 8, 2007 at 9:48 PM
INDYUKE
  • 416 POSTS
Pull the dipstick. If it has the same creamy froth on it instead of oil you might have a blown head gasket. Screw a mechanical oil pressure guage into the block and test the oil pressure that way. Ford oil pressure guages are really idiot lights connected to a stick. Anything from 7-80psi will register in the middle of the guage. Anything less than 7psi will read zero. You probably have SOME oil pressure, so use a mechanical guage to get an accurate reading.
Nov 9, 2007 at 7:23 PM
