leaksalot
FORD F-150
dear bob and ken my 1994 f150 5.0 302 2wd truck with155000 miles on it. Leaks from the oil pan on all sides and a little off the cranks front and rear main seals my repair book stated that the radiator,fan shroud , fan and fan pulley must be removed and that the enigne should be lifted out and discounected from the exaust system what do you think the oil pan gasket and seals will cost me after parts and labor ballpark and how long should it take to repair
thank you for your help and time
Apr 16, 2006 at 1:29 AM
LOSONE
  • 1,616 POSTS
The R & R of the oil pan and reseal the engine pan should be about $300.00 give or take. The rear main seal replacement will require removing the transmission which will at least double the amount.
Good luck
Apr 16, 2006 at 9:53 AM
