inner door panel removal
FORD F-150
1HANDYMAN1
How do you remove a inner door panel from a 2002 Ford F-150?
Dec 9, 2006 at 12:39 PM
CATCH_15
  • 250 POSTS
Most new door panels are the same, so I'll give it a shot. First of all, make sure you have removed all of the screws that hold the panel on. Next use a door panel tool to pry the edges of the panel to loosen the clips. Once you get it loose, it should slide up and be completely loose. Work it around the handles etc., and disconnect all the electrical hookups.
Dec 9, 2006 at 9:40 PM
HEY_WIRE
  • 25 POSTS
if you still have your owners manual then it will tell how to remove it so you dont miss anything and screw something up
best of luck
Dec 10, 2006 at 12:15 AM
