OIL PAN
Removal
Remove fan shroud.
Remove upper intake manifold.
Remove front engine mount-to-frame nuts and raise engine.
On A/T models, disconnect oil cooler lines from radiator.
Disconnect exhaust pipes from exhaust manifold.
Drain engine oil.
Support transmission and remove transmission crossmember. Remove oil pan bolts and lower oil pan.
Remove oil pump bolts and pick-up tube nut.
Lower oil pump assembly into pan.
Remove oil pan from vehicle.
Installation
To install, reverse removal procedure. Apply silicone sealant at front and rear corners of oil pan surface and cylinder block, and where timing chain cover meets cylinder block. To install remaining components, reverse removal procedure.
Nov 9, 2017 at 2:27 PM
(Merged)
