heater problems
FORD F-150
MSF7715
I just got a 1993 ford f-150 2 wheel drive with a 302( 5.0) when i turn the heater on all i get is cold air, i have already replaced the heater coil and thermostat. what am i missing. i have been told that i need a heater control valve but no one has one listed for this truck.
Jan 16, 2006 at 5:43 PM
BABYBLUE_33
What about the heater core and make sure the original engine is in it.
Jan 19, 2006 at 3:12 PM
10FOTUCK
  • 28 POSTS
Im having the same problem with my car. So far I have changed thermostat,flushed radiator, but I put too much antifreeze in it. So, now I have about 1/2 to 3/4 gal. antifreeze and the rest water. Made sure the vent is closing so you dont get no outside air, radiator has 2 pin holes so I will replace it next and I put a piece of cardboard in front of the radiator and that helped alot mind boggling huh! well good luck! You know you might look and see if there is a fuse for the heater either under the hood or under the dash.
Jan 20, 2006 at 1:50 PM
MSF7715
when i installed the new heater core i forgot to reatach the cable to the box. so when i turned the knob from hot to cold the hole cable was moving and it wasn't operating the door in the fan box :oops:
Jan 20, 2006 at 2:34 PM
