1994 F150 210K 302ci. A noisy but functional fuel pump in front tank was replaced (by me). After installed, It did not work when I flipped the switch to the front tank. It ran only while using the rear tank (in which I replaced the pump 2 month earlier). As I drove, fuel was pumped from my rear tank to my front tank. I was running out of gas while my front tank was filling up! I thought the two lines to the pump were different sizes and that I couldn't have switched them. This was not a problem before. I pulled the bad pump from the tank and checked to see if it had a short circuit. It show to be ok...Could it be a fuse? The pump and tank are removed as I wait on the replacement. Why did the fuel get pumped into the tank with the bad pump? How do I avoid this with the new replacement pump? Can I drive my truck with the front tank removed, using only the rear tank? Jerry
Oct 28, 2007 at 1:21 PM
