Front Brakes
FORD F-150
SPINNY
I have a 95 F150 4x4 351 with 220,000 miles.
The front brakes (pads/rotors) need replacing, I have replaced brakes on a 2 wheel drive but never on a 4x4.....am I in for a big job? ( It has manual locking hubs)
Thanks
spinny
Apr 11, 2007 at 5:19 PM
BOOTDOG
  • 665 POSTS
if you never done the rotors before it can be kinda tricky. i know you need a special 4 wheel drive socket to remove the nut. just be sure, if you do it yourself, take your time and look for snap rings, clips, key ways and springs inside the hub. get a rag and lay each piece in a row so when you install them back, just start replacing the last piece that came out first and so on. good luck
Apr 11, 2007 at 6:23 PM
