Ford F150 6 cylinder 1996 4x4 - 75,000 miles -stick 5 speed
1996 FORD F-150
ART HERBST
the truck will not start turns over but the battery seems to drain over night, i put the charger on it charges really fast. brand new battery sears 700 crank power.replaced,plug wires , distributor cap roter,plugs,module,coil, distribtor tested good and charging,relay module, checked all fuses,the battery gage inside the truck does not go to the middle of the gage it is below the letters on the negative side of the gage, if the gage needle is within the letters possitive side the truck will start after the fuel pump sound stops,and willstart all day and maybe the next morning, but if it starts the next morning I put the charger on the batery and it shows low but again charges real fast 5 minutes.used analizer no short appears ,machanic did this. HELP PLEASE,ALOHA ART. HILO HAWAII.
May 17, 2007 at 8:59 PM
AUTOPOP
  • 49 POSTS
Perform alternator output test and see what it's doing, my guess is it has bed diode and not charging battery fully.
May 18, 2007 at 12:39 PM
