2000 Ford F150 Lariat extended cab, 4.6 V8, 124K mi. Both tail lights, right brake/turn signal light won't work. Both bulbs looked good, but replaced both bulbs anyway. Checked under dash & under hood fuses, nothing blown. Sockets appear OK, but do not have volt/ohm meter available to check for voltage or ground in socket. Front lights work fine. Recently had right quarter panel replaced & truck painted. Have looked under rear of truck, trying to trace wiring harness, but lose it under the middle of the tailgate where the wiring harness splits left & right. I don't know where to look within the frame to check for a loose connector or what/where else to check. Any help is greatly appreciated.
Mar 16, 2007 at 9:38 PM
