Ambient air temperature sensor???
FORD F-150
BRENTMELISSA
I have a 1999 Ford F150 4.2 with 168000 miles. The truck has been well maintained, regular tune ups ect... Problem is: check engine light is on, loss of power, slight skip both at idle and driving, using alot of gas. Had friend put it on his code reader, he said it showed a faulty ambient air temp. sensor. :shock: What is this and what does it do? As far as I've been able to find, there's not supposed to be one on it! Any info? Could this be the problem? :shock:
Nov 13, 2007 at 10:55 PM
BMRFIXIT
  • 19,053 POSTS
i dont thingk so but its on the air tube between throtle ane air filter
https://www.2carpros.com/forum/automotive_pictures/99387_ford_2.jpg
let your friend give you the codes may be mas air flow sensor or missfire vacuum leak good luck
Nov 15, 2007 at 9:11 PM
