abs brake light won't go off
FORD F-150
hi- I have a 1997 ford f-150 truck with 120,000 miles v-8 engine
we have replaced the rotors brakes and checked the fluids...but the abs and brake light won't go off ...I have good brakes and don't know what else to try
please ...any help would be appreciated...
thanks
cheri
Jun 3, 2007 at 12:39 PM
TAURUSWHEEL
  • 718 POSTS
You need to scan it to get the code(s) that are keeping the abs light on, the lights, abs and brake, can signal different issues.. the abs light should certainly have a code, the brake light could be a couple of different things, something as simple as the parking brake switch..
Jun 3, 2007 at 11:07 PM
BLACKOP555
  • 10,386 POSTS
also your abs module may be going.
Jun 4, 2007 at 2:03 PM
GARG
I had the same problem with my 96 F150 does cruise control work?
Mine came on and cruise control wouldn't work either. Mine was one that was on recall for the speed control sensor.
If speed control sensor is shorted out (this is the recall that will cause them to catch fire mine did that but i was lucky i was in when it happened) it will cause all this too.
Jun 6, 2007 at 12:10 AM
mine did too but we unplugged it..they replaced it and had to replace the wiring too as it burned...went to dealer and they put it on a machine..found out it was the rabs valve gone bad and that shorted out the rabs module..but they want 1000.00 to fix...which I don't have right now..is it dangerous to drive it like it is?
Jun 6, 2007 at 11:16 AM
