97 Ford F150 wierd problems
1997 FORD F-150
GILLMANJR
I have a 97 F150 when I start it, it will not go into gear. Also the brake lights do not work and the ABS light is constantly blinking. I'm pretty sure all these things are related but I'm not sure how. What I do no is that the number 13 fuse is blown and when I replace it all the problems will go away for about 15 minutes and then the fuse will blow again and all the problems will come back. I've replaced the brake light switch and it didn't help does anyone have anymore suggestions?
Oct 19, 2006 at 7:03 PM
CATCH_15
  • 250 POSTS
It sounds like you have a short somewhere in the wiring that is making the fuse blow. You need to trace the short because it is just going to keep blowing the fuse.
Oct 20, 2006 at 10:39 PM
