throttle pedal position sensor need to be replaced
2006 FORD F-150
89,000 MILES • V8 • 2WD • AUTOMATIC
ED FEWLASS
when i press the gas pedal the engine revs up but when i let off the gas pedal it takes a second or two for the motor to throttle down is this throttle position sensor need to be replaced
Dec 13, 2009 at 6:57 PM
BIGJIM79
  • 239 POSTS
Here is the instructions on how to replace the throttle position sensor it is easy because it is plug and play. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Dec 14, 2009 at 2:40 AM
BIGJIM79
  • 239 POSTS
The best way I have found is to take agood throttle body cleaner and wash the whole air intake all the little airways. I would let it set for about 10 mins after spraying down so it has time to work. I hope this helps
Dec 15, 2009 at 7:32 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks for adding you input to this thread as it may help someone with the same model vehicle and issue. Thanks again for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
Apr 21, 2021 at 9:35 PM
