Trying to replace my rear brake rotors, but they seem to be stuck in the hub. Have confirmed that the e-brake is not engaged/stuck. Have sprayed lug and hub joints with PB Blaster as best that I could and am waiting on it to work. The only advice I have found is to then beat on the rotor hub with a sledge hammer (between lugs and on outer hub corner). Any other advice on freeing the stuck rotors? Is there a tool available for this specific issue?
Aug 10, 2009 at 12:03 PM
