2006 Ford F150 paint
2006 FORD F-150
42,000 MILES • V8 • 4WD • AUTOMATIC
OLSALT
What type of paint would I use to repaint the
F-150 5.4 Triton logo on each side of the front fenders?
May 8, 2010 at 3:22 PM
They should be decals. Are you sure it was paint?
May 8, 2010 at 11:28 PM
OLSALT
The decals are on the rear fenders. The front fenders have raised emblems which are probably plastic with F-150 embedded in them. The F-150 is black with the surrounding ared chrome color. The area around the F-150 is raised.
May 9, 2010 at 5:39 AM
If you are sure it is paint, do you plan to spray it or brush it? Either way, since it is a small area, I would recommend just using a enamal paint. However, make sure to prep the area first. If you are planning to paint, it will need sanded so the paint can adhear to the truck.
May 9, 2010 at 5:27 PM
