the fan clutch sounds like a big roar
2006 FORD F-150
4,000 MILES • V8 • 2WD • AUTOMATIC
PORTO
I think the the problem is the fan clutch sounds like a big roar. how can I be sure if that is the problem. took it back to dealer they messed with the muffler to me it sounds the same
Dec 28, 2007 at 12:09 PM
BRENT70
To check the fan clutch-with the engine off try to turn the fan by hand if it turns easy there is no problem with it, but if it is hard to turn or won't turn at all then you need a new fan clutch Here is how you can change it out
https://youtu.be/N_-MLVlBHk8
Dec 28, 2007 at 11:20 PM
PORTO
Thank you very much for your help!
Dec 29, 2007 at 3:28 PM
PPRINCE72
  • 58 POSTS
I have a Chevrolet Z71 and the truck listed above and both squeak in the cold and sound identical to each other. The Chevrolet I have replace everything but the clutch fan on the water pump. My question is, could the clutch fan be making this noise?
May 7, 2021 at 11:21 AM (Merged)
Good morning,
Yes, it could. It is not common but does make noise when it is worn out.
https://www.2carpros.com/articles/how-a-clutch-fan-works
I attached pictures for you of the system below.
https://www.2carpros.com/articles/fan-clutch-removal
THEAPOSTLE13
on a trip, two of the four bolts holding the fan blade came loose and fell off and the two remaining bolts broke off, the bolt studs remain in the water pump assembly. How do I remove the fan to get to the water pump assembly to remove the broken studs and replace the fan bolts.
Good evening
I attached the procedure for you to remove the fan clutch. You will need those special tools to unscrew the fan clutch from the nose of the water pump. Once you release that nut and remove the clutch, all the bolts can be accessed.
JGANAWAY
  • 42 POSTS
I replaced my fan clutch and do you hand tighten or torque it?
You use this tool shown and tighten it as much as you can with a wrench on the nut. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Please let me know if you have questions. Thanks
