Hello, I just purchased this truck used, the other day when I was driving it the mini info/odometer center display quit. I suspected a fuse which I replaced but the one that I removed appeared fine. When I put the key in after the new fuse center showed briefly then went blank again. The new fuse appears OK. I have found online at some forums that this has happened with other f-150 owners. Everything else seems to work fine and the truck runs great. Any suggestions? Does it harm the truck to drive it with this situation?
Oct 12, 2010 at 4:36 PM
