2006 Ford F-150 Engine shaking a little
2006 FORD F-150
58,000 MILES • V8 • 2WD • AUTOMATIC
FORDTRUCK2006
  • 9 POSTS
My truck is starting to shakes a little , but only when I'm in park or idling. It does well while I'm driving on the road. Thanks,
Jesse S.
Nov 8, 2010 at 9:50 AM
Have you checked for vacuum leaks? When was the last tune up?
Nov 9, 2010 at 7:18 AM
FORDTRUCK2006
  • 9 POSTS
I have never done a tune-up. Only the basics like the oil changes and replacing the oil and air filter. I have yet to replace the spark plugs and wires.
Nov 9, 2010 at 7:25 AM
FORDTRUCK2006
  • 9 POSTS
[quote="Jacobandnickolas"]Have you checked for vacuum leaks? When was the last tune up?
Nov 9, 2010 at 8:04 AM
Actually, the mileage is low for the vehicle and a tune up, but I think it may be a good idea as well as checking for vacuum leaks.
Nov 9, 2010 at 10:45 AM
FORDTRUCK2006
  • 9 POSTS
How about the fuel filter? Could that be the source of the problem and perhaps adding some sort of additive to clean the fuel injectors?
Nov 9, 2010 at 10:52 AM
It could be part of the problem. You may want to check fuel pump pressure to see if it is low. Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Nov 9, 2010 at 1:28 PM
