2005 Ford F150 BAD TRANSMISSION
2005 FORD F-150
52,000 MILES • V8 • 2WD • AUTOMATIC
SCOTTKIZ
I JUST HAD MY TRANSMISSION REPLACED AT 52000. FACTORY WARRANTY IS 3/36K. REPLACEMENT IS 3/100K. I AM PRETTY TICKED TO HAVE TO REPLACE SO SOON. I DO NOT HAUL ANYTHING OTHER THAN ITEMS FROM HOME DEPOT AND NOTHING HEAVY. NEVER EVEN TOWED ANYTHING. DO YOU GUYS THINK I SHOULD HAVE ANY RECOURSE FROM FORD? IT SEMS ODD THAT THE REPLACEMENT WARRANTY IS 3 TIMES LONGER. IS THERE A KNOWN DEFECT? THANKS
Mar 30, 2009 at 6:48 PM
BILLYMAC
  • 2,204 POSTS
i understand that you had it replaced under warranty.if this is the case no recourse all they are obligated to do.is repair and it seems they did that. now if i am misunderstanding and you had to pay for it .. then this would be diff
Mar 31, 2009 at 4:28 PM
SCOTTKIZ
i had to pay for the new transmission. 3600 bucks
Apr 4, 2009 at 8:24 PM
BILLYMAC
  • 2,204 POSTS
hi yes contact your ford rep the dealer will give you his number explain what happened and tell him what you want .they stick pretty close to the limits.but can help if the rep wants too good luck
Apr 4, 2009 at 9:26 PM
