2005 F-150 Rear Brakes
2005 FORD F-150
KWM214
Do you have a step by step illustration on how to remove and replace rear brake pads and rotors on my 2005 ford F150 5.4L 4x4 6bolt disc brakes?? I'm not sure how to pull off the disk pad assembly after I pull off the 10mm bolts... I have tried pulling on them they seem not to move at all....[img:7ef66d836c]http://www.2carpros.com/forum/automotive_pictures/122569_0711tr_03_zssbc_brake_installationwench_removal_4.jpg[/img:7ef66d836c]
[img:7ef66d836c]http://www.2carpros.com/forum/automotive_pictures/122569_0711tr_02_zssbc_brake_installationoem_rotors_1.jpg[/img:7ef66d836c]
Nov 26, 2007 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
You need to compress the caliper a little to get the pads to slip over the lip on the rotor.Once caliper is out of the way, remove th ebolts holding on teh mounting bracket and tap rotor from behind with a hammer and it should pop off.
Apr 6, 2021 at 12:12 PM
