Recently I have started to hear a rattling noise in the front end typically when I am in over drive and going up a hill before the transmission shifts down a gear. Since then I have noticed when I lock it into 4 wheel drive only the back tires are spinning. There aren't any noise out of the ordinary while in 4x4 other than the clicking noise when you first engage it, but I have heard that in the past. I was told that the rattling noise came from the front driver shaft rubbing on a heat shield that was bent, but I am now suspicious that there is much more wrong with the four wheel drive not working.
Sep 1, 2010 at 9:11 AM
