2004 Ford F150 computer code
2004 FORD F-150
DGOODWIN
  • 4 POSTS
Engine Mechanical problem
2004 Ford F150 V8 Four Wheel Drive Automatic
Vin 5 engine-3ov- 5.4 liter
The code indicates that cam sensor A on cam 2 is defective.
Which side is cam 2 and is the cam sensor ithat comes up thru the valve cover sensor A?
The timing cover for the right side is out farther than the left if this helps
updated 1/4/10
Replacing the cam sensor did not fix the problem. Need to know wiring test procedure and wiring pin numbers and sensor wire location in the plug that goes into the computer.
Thanks
Jan 1, 2010 at 6:36 PM
MERLIN2021
  • 17,250 POSTS
Sensor 2 is on the drivers side bank and is on the front of the head.
https://www.2carpros.com/forum/automotive_pictures/62217_cps_1.jpg
Jan 1, 2010 at 8:55 PM
MERLIN2021
  • 17,250 POSTS
If you need more help, reply here by hitting reply to question button and asking the next question, I dont know what you need!
Jan 5, 2010 at 2:05 AM
MERLIN2021
  • 17,250 POSTS
There are quite a few codes for cam sensor problems, if you could narrow it down I can be of better service, what was the exact code?
And to expidide this instead of going to Mike, post your answer here by hitting the reply to question button under this post please!
Jan 6, 2010 at 1:22 PM
DGOODWIN
  • 4 POSTS
It was PO345 code. Finally took truck to Ford service today. Tech said it sounded like the wrong timing. The 5.4 L has 2 different motors that look the same he said. only difference is the timing. Orginal engine I replaced with a salvage yard one. Anyway will know for sure soon.
Thanks for all your help.
Jan 7, 2010 at 7:40 PM
MERLIN2021
  • 17,250 POSTS
Keep me in the loop please, I would like to know how this turns out!
Jan 8, 2010 at 2:39 PM
DGOODWIN
  • 4 POSTS
This turned out to be the cam spocket on the right head. The spring was stuck. Replacement of spocket
repaired the problem. Thanks for all your help
Feb 10, 2010 at 9:39 AM
MERLIN2021
  • 17,250 POSTS
Glad it all worked out...
Feb 10, 2010 at 12:51 PM
