2004 Ford F150 battery change
2004 FORD F-150
DRLUCK777
Computer problem
2004 Ford F150 Two Wheel Drive Automatic 190000 miles
Had to put in a new battery after new one installed truck won't start acts like the anti theft device is enabled, all dash lights come on all things work inside but will not turn over, is there a reset button or relay that needs to be replaced
Jan 12, 2010 at 11:59 AM
SERVICE WRITER
  • 9,123 POSTS
Do the light dim when you try to crank it?
There is a tsb on this:
ISSUE
Some vehicles may exhibit a no crank condition due to an open circuit in the starter relay to starter motor circuit at the starter motor connection.
ACTION
Follow the Service Procedure steps to correct the condition.
A new starter terminal wiring pigtail kit is released eliminating the need to replace the entire harness for the terminal connection.
NOTE TERMINAL KIT ONLY SERVICES THE STARTER RELAY TO STARTER MOTOR CIRCUIT. THE KIT DOES NOT SERVICE STARTER MOTOR BATTERY POWER CIRCUIT.
Refer to instruction sheet contained in Wiring Pigtail Kit for wiring harness service procedure.
part #6u2z-14s411-na
Get a look at the connection at the starter for dirty or poor connection.
Jan 12, 2010 at 12:29 PM
