The turn signals started "skipping" and my local parts manager said it sounded like the flasher relay needed to be replaced. I purchased a replacement and went home to install it. I have changed several of these in other vehicles and figured in would be in the leg area on the driver's side. Could not find it anywhere and checked my Owner's manual. Nothing there so I headed to my local Ford dealer. Talked to someone in parts and the in service and no one could tell me where the flasher relay was located. I would like to save the cost of taking it into the dealer when all I have to do is pull out the old one and put this one it. The part is a cube with four prongs; three parallel and the top (or bottom) perpendicular. I found under the hood an outlet for a plug of this type, but this was not a flasher outlet (per the Owner's Manual) nor would the relay fit (it was too large. If you could help direct me to the location for this relay, it would be appreciated.
Jan 28, 2010 at 6:20 PM
