Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Steering
Tie Rod End
Replace/Remove
tie rod replacement
2003 FORD F-150
188,000 MILES • V8 • 2WD • AUTOMATIC
SHELL1967
MEMBER
1 POST
FOLLOW
what is wrong when you back up and turn wheels to the right the front tires drag and it is hard to keep it on the road please help.
Jan 15, 2009 at 7:05 AM
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny.
Here is the information you requested. Here is a tutorial showing how to replace tie rod ends:
https://www.2carpros.com/articles/tie-rod-end-replacement
I've attached picture steps below for the replacement of the inner and outer tie rod ends on your Ford F150. After this repair you will need to have a front end end wheel alignment. Hope this helps and thanks for using 2CarPros.
Jun 24, 2021 at 11:08 PM
