2003 Ford F150 OBDII P-1518 Trouble Code
2003 FORD F-150
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
FBRAND
I have a 2003 F150 with a 4.2L engine coming up with a OBDII P-1518 code. Any suggestions on repair? Please and thank you!
Aug 26, 2009 at 9:36 PM
MJR346
  • 132 POSTS
P1518 - Intake Manifold Runner Control Malfunction (Stuck Open)
Guess is there are butterflies that change the airflow in the engine with RPM. There are some bushings that break or bind up occasionally and apparently that is what happend here.
Recommend replacing the upper intake gaskets and bolts at the same time (a couple of hour job I would recommend more for a pro technician or an advanced shade tree)
Aug 27, 2009 at 7:37 PM
