Transmission problem
2003 Ford F150 V6 Two Wheel Drive Manual 45000 miles
I can't shift gears when the engine is on. If the engine is off, the gears will shift. If I start the engine in gear, it takes off. The clutch is loose and will not engage. There is a leak coming from a rectangular seal on the transmission casing. The problem started after I got the fluids changed at a lube shop
Dec 10, 2007 at 12:35 AM
