2003 Ford F150 Fuses, wireless remote or alternator drainin
2003 FORD F-150
177,000 MILES • V8 • 2WD • AUTOMATIC
JOSEM198613
  • 5 POSTS
Charging system symbol illuminated, battery gauge on dash dropped from normal to low, truck turns off after 20 mins or so. What could be the problem?
Jul 26, 2010 at 9:35 PM
Have you had the alternator tested?
Jul 26, 2010 at 9:36 PM
JOSEM198613
  • 5 POSTS
No i have not, need to recharge battery first then i will test the alternator, if that is not the problem coudl it be the wireless remote?
Jul 26, 2010 at 9:40 PM
It could have something to do with it. Check the alt. If it shows good, let me know. I explaine how to perform a draw test. If there is a draw, I'll have you remove one fuse at a time until the draw stops. At that point, we'll know what circuit the problem is coming from.
Jul 27, 2010 at 12:51 AM
JOSEM198613
  • 5 POSTS
ok, i will take the battery to get recharged then i will check the alternator. ill get back to you some time today. thank you very much!
Jul 27, 2010 at 8:11 AM
If you can make it to a parts store, they will check the alt for you. If you can't, here is a how to for checking it yourself. It is very easy to do.
https://www.2carpros.com/how_to/how_to_test_alternator.htm
Let me know what you find.
Jul 27, 2010 at 9:37 PM
JOSEM198613
  • 5 POSTS
The alternator works fine. the battery is charged. the symbol is still illuminated and its still not recharging the battery.
Jul 30, 2010 at 7:40 PM
You must have a fuseable link between the alt and the battery that is bad. Check them for continunity.
Jul 31, 2010 at 12:14 AM
JOSEM198613
  • 5 POSTS
ok, can i check them by using the "light buld' tester?
Aug 2, 2010 at 8:38 AM
Not sure what that is. If it is a regular test light, no. If it is self powered, you can, but pay attention if the light is dim. I would recommend an ohm meter that has a continunity setting. That way you can see how much resistance is in the wire.
Aug 3, 2010 at 12:35 AM
