2003 Ford F150 4 wheel drive will not engage
2003 FORD F-150
59,000 MILES • V8 • 4WD • AUTOMATIC
LARKELLER
I have a shift on the fly knob on the dash to engage 4 wheen drive. When it is turned, nothing happens. No indicator light, no sounds, no engaging. The fuses check out OK. I used to hear the click of a relay behind the dash when the switch was turned. Now there is no sound.
Dec 6, 2007 at 1:43 PM
GARYL2
The switch in the dash that engages 4 wheel is probably bad. The switch turns the indicator light on, It also engages the actuator at the axle. I had the same problem with my f-150. I had the switch replaced. Everything ok now.
Dec 16, 2007 at 9:55 AM
Yep, yep, here is how to change the switch out to help fix the problem. Check out the images (below). Please let us know what happens.
Jul 5, 2024 at 5:12 PM
