Can the gears be changed in the differential in the rear?
Aug 3, 2009 at 5:13 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You can re build the rear diff but it is a specialist job as the set up and pre load of the bearings and gear sets are precise, more so with a limited slip diff, the crown wheel and pinion are sold as a matched set, spider gears are sold normally as a set as well.
