2002 Ford F150 Bad vibration
2002 FORD F-150
44,260 MILES • V8 • 4WD • AUTOMATIC
KAB3357
All of a sudden our truck vibrates so bad when we reach 45-50 mph. All new tires kept fluids changed and checked and have inspected everything. Nothing appears broke, shocks. wheels or anything else we could check. Would like to know what we can do to fix this problem. This started out just slightly now it feels like the truck might shake apart. Air pressure all good in tires we are stumped. Any and all help will be appreciated. Thanks
Aug 29, 2010 at 5:38 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile...Imma CJ Guy,
I would start with a careful inspection of your "U" JOINTS (universal joints)
Park on level ground
CHOCK BOTH SIDES OF YOUR WHEEL (prevent rollage either way)
Put in Neutral
Go to rear axle area
Go under and grasp your driveshaft one hand......yoke at differential with other.
Wring it like a wash rag both directions---you do not have to do it fast....looking for "Slop"
There should be no movement between the 2 yokes, or the "+" in the center (NONE, not even teeny tiny slop is acceptable)
The Entire "U" Joint...both yokes...Should move in Unison as if they were one part (if they are greased on regular intervals, they will last a long time, See Chilton or Haynes Manual for SCHEDULED MAINTENENCE)
NOW MOVE UP TO THE TRANNY END
Perform the same test.
If you have 4X4, you will do the front driveshaft the same way.
THIS MAY BE YOUR PROBLEM---Needing a New "U" Joint---maybe 2
On Jeeps--sometimes we get a BIG OLE GLOB OF MUD on the inside of our rim...This really throws balance out.
Also look for a CLEAN SPOT on your rim (outside and in) where you might have thrown a Wheel Weight
Respond
The Medic
Aug 29, 2010 at 8:25 PM
