Leaky back window
2001 FORD F-150
Four wheel drive.
Back window leaks. I was told that the cargo light would solve problem it appears to me that the light has nothing to do with sealing the window. will changing the light help me? also, do i need to remove the head liner to get to the clip on the wire or is mine just stuck?
Nov 11, 2008 at 12:32 PM
IMPALASS
  • 3,112 POSTS
To better assist you can you tell me if you have the regular F150, four wheel drive pickup or is it a F150 four wheel drive super crew? Also, can you provide the exact engine size by liter and the eighth digit of your VIN number to better answer your question?
Nov 11, 2008 at 7:42 PM
Engine: 5.4L.
Extended cab.
Eighth Vin# is L.
Nov 11, 2008 at 9:50 PM
IMPALASS
  • 3,112 POSTS
Hello, Well, I attached how to remove and replace the back window. Hope that helps. Also, it appears that this may be a common problem as they have a technical service bulletin on it. I have provided that also. Removal:
https://www.2carpros.com/forum/automotive_pictures/248015_1_30.gif
Remove the rear seat back. 1 Remove the bolts. 2 Lift up to remove the rear seat back.
https://www.2carpros.com/forum/automotive_pictures/248015_2_38.gif
Remove the safety belt guide bolt. 1 Lift the cover. 2 Remove the bolt
https://www.2carpros.com/forum/automotive_pictures/248015_3_28.gif
Remove the roof side rear trim panel. 1 Remove the pin-type retainers. 2 Pry and release the clips. 3 Slide the roof side trim panel out of the retainers and remove the roof side trim panel.
https://www.2carpros.com/forum/automotive_pictures/248015_4_21.gif
Remove the coat hooks. 1 Remove the two screws. 2 Remove the two coat hooks.
https://www.2carpros.com/forum/automotive_pictures/248015_5_15.gif
Remove the dome lamp. 1 Carefully pry the lens out of the dome lamp. 2 Remove the dome lamp screws. 3 Remove the dome lamp. Lower the back half of the roof trim panel. Cut the foam butyl from around the back window glass.
https://www.2carpros.com/forum/automotive_pictures/248015_6_13.gif
Remove the back window glass. 1 Remove the 12 nuts. 2 Remove the back window glass. Remove any remaining foam butyl from the window glass frame. INSTALLATION : Clean the back window glass with an alcohol-free cleaner. Apply 8 mm foam butyl, or equivalent meeting Ford specification WSB-M2G234-C to the back window glass. Start at the bottom middle and work around.
https://www.2carpros.com/forum/automotive_pictures/248015_7_6.gif
Install the back window glass. 1 Position the back window glass. 2 Install the 12 nuts. Position the roof trim panel.
https://www.2carpros.com/forum/automotive_pictures/248015_8_7.gif
Install the dome lamp. 1 Position the dome lamp. 2 Install the dome lamp screws. 3 Install the lens.
https://www.2carpros.com/forum/automotive_pictures/248015_9_6.gif
Install the coat hooks 1 Position the two coat hooks. 2 Install the two screws.
https://www.2carpros.com/forum/automotive_pictures/248015_10_5.gif
Install the roof side rear trim panel. 1 Slide the roof side rear trim panel into retainers and position the roof side trim panel. 2 Install the clips. 3 Install the pin-type retainers.
https://www.2carpros.com/forum/automotive_pictures/248015_11_5.gif
Install the safety belt guide bolt. 1 Install the bolt. 2 Install the cover.
https://www.2carpros.com/forum/automotive_pictures/248015_12_4.gif
Install the rear seat back. TSB Article No. 04-2-2 02/09/04 BODY - BACK GLASS - SLIDING BACK GLASS WINDNOISE/WATER LEAK - SEAL REPLACEMENT FORD: 1999-2003 F-150 ISSUE Some 1999-2003 F-150 vehicles may exhibit windnoise and/or a water leak from the back glass area. ACTION
https://www.2carpros.com/forum/automotive_pictures/248015_13_4.gif
To service, order and install Service kit 3L3Z-1542052-AA. Refer, to the installation instructions included in the kit. It will also be necessary to obtain a tube of Motorcraft Instant Adhesive (TA-19) or equivalent for this repair. NOTE THE KIT APPLIES TO BOTH MANUAL AND POWER SLIDING REAR WINDOWS.
https://www.2carpros.com/forum/automotive_pictures/248015_13_5.gif
Parts Block OTHER APPLICABLE ARTICLES: NONE WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage OPERATION DESCRIPTION TIME 040202A Install Backlight Sliding 0.6 Hr. Seals (Includes Time To Remove Rear Seat Back On S/Cabs Vehicles Or To Loosen Upper Portion Of Back Panel On Regular Cab And Super Crew Vehicles DEALER CODING CONDITION BASIC PART NO. CODE 15420A26 33
Nov 11, 2008 at 10:20 PM
