2001 Ford F150 front end squeeks
2001 FORD F-150
108,000 MILES • V8 • 4WD • AUTOMATIC
KINGMOSES87
i just recently bought a pre-owned 2001 supercrew f150 ,and ever since i had it i notice that not only my truck but alot of other trucks the same as mine have a similar squeak in the front end when either turning the wheel or driving over speed bumps...what is that and what is it from?
Oct 16, 2008 at 12:45 AM
2CARPRO JACK
  • 11,533 POSTS
Usually from the ball joints. If you notice, there arent any grease fittings .I have carefully drilled into the center of the bottom of them and installed fittings.
Oct 16, 2008 at 8:11 AM
KINGMOSES87
will the ball joints eventually give out and cause a problem from that noise?
Oct 20, 2008 at 3:42 AM
2CARPRO JACK
  • 11,533 POSTS
Lack of lubrication is what will cause the failure and is causing the noise.So, yes eventually they will fail
Oct 20, 2008 at 7:34 AM
