2001 Ford F150 Engines hesistates at 1700 rpms to 2200 rpms
2001 FORD F-150
16,400 MILES • V8 • 4WD • AUTOMATIC
MNOVELLI
My truck hesistates at 1700 rpms to 2200 rpms. I used to have codes po171 and po174. But fixed them by replacing the TPS. Also in the process I ended up replacing the MAF as well. The fuel filter has about 15,000 to 20,000 on it. Also, when its hot out the problem is worse. Any insight would be great. I'm thinking it might be fuel pump or pressure regulator, not sure though.
Jul 24, 2010 at 4:30 PM
Hi mnovelli, Welcome to 2carpros and TY for the donation
Some of your possibilities- Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 24, 2010 at 6:56 PM
