2001 Ford F150 emmisssions
2001 FORD F-150
70,000 MILES • 4 CYL • 4WD • MANUAL
SABRES1981
I have a check engine light that keeps coming on. first it has i was running to lean have replaced 02 sensors air intake sensor and now egr valve. i clear the codes and the light keeps coming back on any suggestion on what it could be
Nov 16, 2009 at 4:45 PM
If the same code keeps coming up, chances are you have a vacuum leak somewhere. It could be a vacuum hose, intake gasket...
When more air is allowed into the system, the engine will run lean.
Nov 16, 2009 at 9:25 PM
